Reporting toolkit and XLSX File
Sorry.  The attached zip file should contain all the missing files.  Thanks for helping.
Message 11 of 16
(988 Views)
I see that you are taking in a .tsv and just adding a .xls extension so that you can use the Save Report to File.vi. Maybe this is causing the issue. Try converting the TSV to a format Excel can understand (.csv, .xls, etc) using online tools. Also, please upload the tsv you are using so that I can reproduce the issue.
On a separate note, the next time you want to send your code to someone and don't want to forget any subVIs or dependencies, you can do a Souce Distribution.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
Message 12 of 16
(971 Views)
I can't reproduce the problem anymore.  When I can reproduce it, can I post on this thread again?
Message 13 of 16
(957 Views)
Sure thing. Let's keep using this thread for this issue. Keep me posted.
Daniel REDS
RF Systems Engineer
Help us grow.
Message 14 of 16
(953 Views)
The example you linked to, I get an error when I click on it.  Can you link it more permanently or give the terms to search it out?  I have RGT for 2012 and Excel 2010 and all I want to do is open an .xlsx file an read data out of it.  Can't figure it out...
Message 15 of 16
(917 Views)
Hi AFH,
Maybe this link is going to help you.
https://decibel.ni.com/content/docs/DOC-3033
MCOTO
Message 16 of 16
(891 Views)
