06-08-2012 11:21 AM
Sorry. The attached zip file should contain all the missing files. Thanks for helping.
06-11-2012 03:54 PM
I see that you are taking in a .tsv and just adding a .xls extension so that you can use the Save Report to File.vi. Maybe this is causing the issue. Try converting the TSV to a format Excel can understand (.csv, .xls, etc) using online tools. Also, please upload the tsv you are using so that I can reproduce the issue.
On a separate note, the next time you want to send your code to someone and don't want to forget any subVIs or dependencies, you can do a Souce Distribution.
06-12-2012 09:54 AM
I can't reproduce the problem anymore. When I can reproduce it, can I post on this thread again?
06-12-2012 10:24 AM
Sure thing. Let's keep using this thread for this issue. Keep me posted.
02-07-2013 01:45 PM
The example you linked to, I get an error when I click on it. Can you link it more permanently or give the terms to search it out? I have RGT for 2012 and Excel 2010 and all I want to do is open an .xlsx file an read data out of it. Can't figure it out...
02-08-2013 03:41 PM
Hi AFH,
Maybe this link is going to help you.
https://decibel.ni.com/content/docs/DOC-3033
MCOTO
