Report Generator LV2015 - Breakpoint Set
I opened the Breakpoint Manager and to my surpise, there is a breakpoint set in the following file:
C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\addons\_office\_wordsub.llb\Word_Set_Paragraph_Format(adv).vi
I have multiple versions of LabVIEW on this PC. LabVIEW 2013 also has a breakpoint in this file. I'd like to see if other users have this breakpoint.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,299 Views)
Yes! It is there on LabVIEW 2015 SP1.
(4,286 Views)
It is not present in LabVIEW 2016.
(4,253 Views)
Accepted by stevem181
I believe this was a bug found during the 2016 beta.  I don't remember exactly how the discussion went but I don't remember anyone saying that they saw the breakpoint hit, just that they found it, and it probably shouldn't be there.
(4,224 Views)
Thanks guys for taking the time to check on this issue.
The problem has been solved in LabVIEW 2016 and if people using older versions run across it they may find this thread and know they can safely delete the breakpoint. So it makes sense to mark it solved.
(4,152 Views)
