Report Generation in Executables
Using LabVIEW 2012 SP1, I created a vi that opens an Excel file and puts a string of data (time stamp and a data bit).  It iterates once a second and appends the file just fine on my laptop.  My problem is that when I create an executable, the Report Generation does work.  The while loop works fine collecting the data but Excel does not open.  Can someone tell me what the trick is?
Brad
Message 1 of 19
(6,579 Views)
Pretty hard to say without seeing some of the project.  A couple of obvious things to check:
Are there relative paths to the report?
Does the target have the file to open?
"Should be" isn't "Is" -Jay
Message 2 of 19
(6,565 Views)
Hi Brad,
I had a similar problem. The fix was to include "NIReport.llb" in the build.
The Report Generator uses dynamic calls to sub vis so they don't automatically get included as dependencies.
However, I seem to recall that errors were generated in my case which you did not mention seeing.
You might want to make sure error handling is working in your code.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 3 of 19
(6,552 Views)
As mentioned above you probably need to do something like this:
http://zone.ni.com/reference/en-XX/help/372120A-01/lvrgthelp/rgt_stand_alone_apps/
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 4 of 19
(6,526 Views)
In addition, it will not work without Excel being installed on the target computer.
Message 5 of 19
(6,491 Views)
You are correct in that I did not have NIReport.llb in the build and I did not have an error out indicator.  I tried to ensure that the Report Generation was included in the build, enabled debugger and diplayed the error out indicator.  I still had the problem that excel did not open.  Here is the end of the error message:LabVIEW attempted to load the class at this path: ...\labvi3w\vi.lib\utility\NIReport.llb\Excel\NI_Excel.lvclass.   Somehow I am not completely getting everything into the build.
Thanks for your help.
Message 6 of 19
(6,478 Views)
Thank you.
I can't seem to figure out how to get this into my build:
  • labview\vi.lib\Utility\NIReport.llb\Excel\NI_Excel.lvclass if the application uses Microsoft Excel.  (copied from the link you sent)
Message 7 of 19
(6,477 Views)
Accepted by Brad_Henry
You should be able to add it by right clicking on "My Computer" in the LabVIEW project and selecting "Add" » "File..."
In the window that pops up you should be able to navigate to your LabVIEW Installation folder to the Excel Class directed. An example of its path on my system for LabVIEW 2012 looks like this: (You will likely need to change this)
C:\Program Files\National Instruments\LabVIEW 2012\vi.lib\Utility\NIReport.llb\Excel\NI_Excel.lvclass
Once the class shows up in your project you should be able to add it to the "Always Included" section of the "Source Files" category in the build specification.
Message 8 of 19
(6,470 Views)
That path is the same on my computer was successful in adding it to the build.  I emailed the files to a coworker and hopefully it worked.  It will let you know.
Thanks again.
Message 9 of 19
(6,448 Views)
Hey guys,
Did anything come off this issue?
I am experienceing the same thing, but with word.
I have the NiReport.llb, Dynamic Word vi, NI_Word.Lvclass, Utility folder, Word folder from LVclass - all of these things included in my build.
I also have the " Pass all command line arguments to application" checked too.
My issue is a little different though, " The executable creates an empty word file and with no data in it. Which beats me.
I have word installed in the target computer too.
I have followed everything from NI database and i still have this issue.
Can anyone share some insight into this issue please.
RP.
Message 10 of 19
(6,317 Views)
