Replacing a 2D array section of a 3D array
I have a pre-allocated 3D array. The pages represent different measurement channels. The rows are voltage and current. The columns are data points. So a size could be [10][2][10000] ([channels][I+V][data]).
A new array of data points arrives and I want to insert it into the array. Let's focus on 1 channel for now (the first one, page index 0). How can I insert this new 2d array into the 3d array at a specified location. Say each data array that arrives is 100 points. The first iteration must be inserted at row 0, column 0. The second data array at row 0, column 100, etc. But when I wire both the page and column index of the replace array subset function, the function only accepts 1d arrays.
I have a version that works, but I don't think it's the most efficient, since it uses a for loop instead of writing the data directly. The final version may have a lot of data (1M points) and a lot of channels (100+), so I'd like to be as efficient as possible. (in the future, I'll use a DVR for the buffer, but that's not the issue now).
Any suggestions?
Maybe even a better data structure?
(218 Views)
From a performance point of view, I would like to recommend ensuring that you write data strictly sequentially. You can clearly feel the difference:
(201 Views)
Hi Basjong,
Other (but not immediatly better) data structure:
  • 1D array of DVRs
  • each DVR contains a cluster of two 1D arrays (one array for "I", the other for "V"), as you currently use different columns for I/V…
As a 3D array this would require 1M  points * 8 B/point * 2 * 100 channels = 1600 MB: I guess you need LabVIEW-64bit to handle this safely…
Breaking up the data in smaller chunks (like an array of DVRs) might help to manage this amount of data.
Do you really need to hold ALL the data in memory?
Can't you use a (TDMS?) file or a database to store/manage the data?
Yes as you restrict the "entry point" to a certain page+column…
(198 Views)
@GerdW wrote:
Hi Basjong,
  • 1D array of DVRs
A 1D array of a cluster of Voltage and Current is probably better. I tried to be clever by using a single array.
Yeah, I should probably manage this better. Not all channels will be visualized at the same time. So I can keep just the active channels in memory and store all others just in a file.
(172 Views)
Hi Basjong,
You still can go with just one array (per cluster) once you combine voltage+current into a complex number 🙂
(164 Views)
I agree.  Think in terms of the structure of your data.  You have two measurements (Voltage and Current) that are related to each other (by being acquired at the same time, and manifesting different "aspects" of the data you are saving).  They are acquired simultaneously, and any analysis that you do will likely require both to make an interpretation of the data.
So if the basic "quantity of interest" is a Cluster of V and I, the other two dimensions are "Channel Number" (how many simultaneously-acquired sets of V,I data you are handling) and Time, itself. Here, your DAQ device helps you with creating a logical data structure.  Because the DAQ device (probably) gives you N (= 10?) channels simultaneously, and for design reasons gives you a "chunk" of data (say, 1000 samples of your 10 channels) at a time, the "natural" way of saving these data are in a 2-D "Total # Samples" (variable) by "Total # channels" (fixed, 10 in this example).  The "rows" are individual samples of 10 ("columns") channels.  You are taking 1000 samples (of 10 channels) at a time, so these become the rows of your data matrix.  And within each "sample" (row) of each "channel" (column) there is a "pair" (cluster) of Voltage and Current readings.
Is it obvious/intuitive why you'd take 1000 samples at a time and save them in such large "chunks", rather than one sample at a time?
(127 Views)
