Replace Array element based on certain conditions
Hello All,
Please help me if anyone have nice idea.
I want to replace Array elements based on certain conditions.
As per attached Sample,
I have fixed character Array & Some Random values with Array Size.
Here, I need to check Random char with fixed Array. If char is not matching then I need to replace that index value with “NaN”. Once it is matching for one time then next time I need to display Run time value for that particular index.
Munna
Message 1 of 11
(4,835 Views)
Maybe i misunderstood, but it can give you some ideas.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 11
(4,804 Views)
/Y
Qestit Systems
Message 3 of 11
(4,804 Views)
Dear Yamaeda,
Thanks for your reply.
your attached VI is not mathching with my requirement. If 1st time Index is matching then next time we should not display NaN (eventhough its not mathching for next time). I have to display NaN until that index is not matching.
after Matching I need to display Runtime Value....
Munna
Message 4 of 11
(4,777 Views)
Ok, so your program is working as it should? Then what's the question? 🙂
What problem are you trying to solve?
/Y
Qestit Systems
Message 5 of 11
(4,771 Views)
Sorry. I'm thinking to minimize my code.
Just waiting for better solution.
Munna
Message 6 of 11
(4,764 Views)
Accepted by Munna232
Yes, you have way too much code for such a simple problem. Also, your random character generator is flawed, because A and Z will only occur at half the probability of the other characters.
Here's a quick draft how it could be done with less code (LV 2012). Modify as needed. I am sure more simplifications are possible....
Message 7 of 11
(4,754 Views)
Dear Altenbach,
Thanks for your nice idea.
I have made minor changes to your code. Because sometimes i need to check Same character 2-3 times from Fixed array.
I think, once all index values are matching then no need to check.
Munna
Message 8 of 11
(4,734 Views)
You can just do a "AND array elements" on the boolean array for the outer case structure. No need to convert, sum, compare sizes, etc.
Message 9 of 11
(4,719 Views)
Yes.. Thank you altenbach 🙂
Munna
Message 10 of 11
(4,717 Views)
