Repeat same rows multiple times in a result
I have an interesting challenge to repeat same rows multiple times in a result.
As an example, I have a table with 3 records.
| id | Product | Description | Qty |
| 1 | P1 | Product 1 | 2 |
| 2 | P2 | Product 2 | 3 |
| 3 | P3 | Product 3 | 1 |
The result set should look like below with 5 rows
I have tried with UNION ALL, IN Functionalities but missing something in a query.
AB
Kudos are Accepted
Message 1 of 9
(10,211 Views)
Hi AB,
Index the rows as needed in a loop and use the autoindexed loop output…
Are you talking about LabVIEW here at all?
Could you attach your VI?
Message 2 of 9
(10,203 Views)
Index the rows as needed in a loop and use the auto indexed loop output…
Indexing will increase time to extract data base
I am taking about SQL query (UNION ALL,IN)used to extract data from database
AB
Kudos are Accepted
Message 3 of 9
(10,166 Views)
Hi AB,
maybe you should give a FULL view of your task!
So you query some "rows" (aka records) from a database. Then you want to output those "rows" somewhere in a certain order with some of the "rows" duplicated in a "random" scheme.
Atleast that's what I read from your description so far…
Where do you read from?
How do you read the "rows"?
How do you want to (re)order the rows?
Where do you want to store those "rows"?
Message 4 of 9
(10,159 Views)
Your understanding is correct!
Table column
Based column1
based on input array framed
storing not required, need to read in text
Similar to question posted..
AB
Kudos are Accepted
Message 5 of 9
(10,142 Views)
After reading the data from SQL Query you have 2d array.
-Instead of SQL Query, my suggestion would be to use array operations on the array to form the result into required format.
-Using Insert into Array and/or Index Array
uday
Message 6 of 9
(10,132 Views)
Like udka seems to be saying, I'd also suggest getting the simplest data into LabVIEW, and then doing more complicated operations natively in LabVIEW. Although you can write obscenely clever queries (perhaps - I can't!...) in SQL, in many cases LabVIEW is more able to handle what you need (and at least for me, often in a simpler to understand (and more importantly code) way).
I have found in the past I can read multiple orders of magnitude more data out of a database and decimate it in LabVIEW than try and concoct an indexing function within the database to decimate there in the same time.
Once you know the way in which you want to duplicate data, getting LabVIEW to do it (with Insert Into Array as udka suggests, or similar) should be simple.
GCentral
Message 7 of 9
(10,129 Views)
All ready I have implemented by Indexing..
I would like to know any other solution is available.
AB
Kudos are Accepted
Message 8 of 9
(10,110 Views)
Accepted by AB@17
I have got solution by using where and IN keywords in combination
AB
Kudos are Accepted
Message 9 of 9
(10,067 Views)
