Repeat elements of an array
Lets say I have an array like this.
1 0 0 0 1 1 0 0 0 0 0 0 0 1 1 0
0 1 0 0 0 0 0 0 0 0 0 0 0 1 1 0
Now I want to change this array and copy each row n time. Let's say for now n=1    so the array should  become like this.
1 0 0 0 1 1 0 0 0 0 0 0 0 1 0 0
0 1 0 0 0 0 0 0 0 0 0 0 0 1 0 0
and if n=2 then the below table
so i should add the new copied rows and shift the table down. And as can be seen the one before last bit should always follow this pattern 1,01,011 then 0111
Could you please help me to implement it in LabVIEW
(4,298 Views)
Hi tintin,
you might start like this:
I used U16 datatype to represent your 16 bits per row.
The bit setting can be made in dependance of the loop iterator "i" of the inner loop: IF i=0 THEN clear bit ELSE set bit...
(4,287 Views)
Thank Gred
the probelm is if I change the bit in the inner loop then it will change for all n copies. While I would like to follow this pattern    : 1   01  0111   01111
(4,279 Views)
@tintin_99 wrote:
Thank Gred
This is only true when applying the same bit modification in each iteration.   You can setup an array of values that contains the modifications that need to be done in each iteration and index this in the inner For Loop. If I correctly understood your demand, an OR operation should be the one that needs to be added to the inner loop.
(4,264 Views)
