Renaming a Library Programmatically
Manually, I can open a .lvlib file, Save As ..., then select Rename.  Then all of the owned items will be linked to the new name.  I want to do that programmatically.
This doesn't work:
paul_cardinale_0-1664982241107.png  All the owned items are still linked to the old (still existing) .lvlib file.
This doesn't work:
paul_cardinale_1-1664982348924.png   It throws an error because the original .lvlib file exists on disk.
This does work:
paul_cardinale_2-1664982425383.png  But it's a private method.  Is there a way to accomplish the same thing without using a private method?
Message 1 of 10
(4,684 Views)
Accepted by topic author paul_cardinale
It seems you need to Save a Copy (and remove the old one), that worked for me.
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 10
(4,660 Views)
@paul_cardinale wrote:
That path takes me back 20 years 😁.
Message 3 of 10
(4,580 Views)
Hah! I didn't react to the A:! It didn't work because Paul forgot his floppy!
Qestit Systems
Message 4 of 10
(4,563 Views)
MY first box of 10 floppy disks cost $90.  Each disk held 320,000 bytes.
Message 5 of 10
(4,545 Views)
8 inchers?
Qestit Systems
Message 6 of 10
(4,499 Views)
@Yamaeda wrote:
8 inchers?
No, 5 1/4".  When I bought the computer, I was somewhat concerned about the fact that it had 5 1/4" instead of 8" because at the time, there was no standard for the 5 1/4" floppies; there were a variety of different formats.
Message 7 of 10
(4,474 Views)
Ouch.  That's very expensive discs.
What year was that?
I remember 3 1/2" disc only cost $1 in 1987.
George Zou
Message 8 of 10
(4,469 Views)
What year was that?
1983
Message 9 of 10
(4,463 Views)
What year was that?
As a side note, today, cost/bit of electronic memory is more than 100 million times less than in 1980.
So the amount of storage in a card/stick that costs $10 today would have cost more than one billion dollars in 1980 (and those are 1980 dollars).
Message 10 of 10
(4,402 Views)
