Removing specific values from an array
Good day:
I'm trying to code a program that does the following transformation:
{1, 2, 3, 2, 3, 4, 5, 6, 5, 6, 7} ---> {1, 2, 3, 3, 4, 5, 6, 6, 7}   (Bold numbers have been removed)
Technically, I'm trying to do the comparison x_(i+1) >= x_i. If this is false, remove x_(i+1) and the data in the corresponding row.
Text-wise I believe it looks like this:
for i=2 to Length(A)
   j = i - 1;
   if A[i] < A[j]
      Delete A[i];
   else
end
However, I'm having alot of trouble trying to program using a mix of for/case loops and shift registers.
Could someone point me in the correct direction?
(3,842 Views)
What is your LabVIEW version?
Show us what you tried!
Maybe you should start here and add a shift register to compare current with previous to create the decision for the conditional tunnel. Shouldn't be hard. 😉
(3,833 Views)
Here's one possibility. Modify as needed.
(3,818 Views)
Of course you need to decide how to handle other conditions such as an input of:
1,2,3,1,2,4,5,6,5,6,7.
Should the output be:
1,2,3,2,4,5,6,6,7 (current code)
or
1,2,3,4,5,6,6,7
(3,801 Views)
Hi Alten, thanks for your fast reply.
It should reread the entire array and ensure that the condition holds for all subsequent values - 1,2,3,4,5,6,6,7.
I will try the VI u posted.
Thanks again!
(3,790 Views)
OK, the you need to make a few small modifications. See if this works:
(3,761 Views)
