05-27-2009 08:40 AM
I am a behavioral researcher who is just learning Labview. I just purchased the full Professional Development program after using signal express and a DAQ board for the past 2 years. I now have hundreds of files collected that I would like to automate processing for as well as create a program to process new data collections. I was able to create some of the steps but am really having trouble getting out bad data first. I have tried numerous examples found on the forums and in the manuals - but my inexperience is showing. I am hoping someone can help me past this step (and if you have suggestions for future steps all the better!).
My signal is from an actocardiograph machine that records two signals on the same time scale: fetal heart rate in beats per minute (generally 100-190 bpms) not an electrical signal so no QRS wave, just a doppler measurement) and a second signal of activity in arbitrary units (0-100). Movement artifact is present throughout the recording in the heart rate signal. I need to delete artifact and interpolate if possible. I cant seem to get any of the VIs to process the signal for this - and I think its because I dont know the best one to use or how to configure it properly. There are also instances of artifact that I need to remove completely due to interference from my ultrasound machine that is within this range but clearly a repeating pattern of a steady 146-148 bpms.
Any suggestions or examples of exactly HOW to use VIs such as removing outliers (e.g. how do I specify the upper and lower range for the Y values of 100 to 190) or wavelets would be GREATLY appreciated!
Solved! Go to Solution.
05-28-2009 10:13 AM
Have you seen the following forum?
http://forums.ni.com/ni/board/message?board.id=170&requireLogin=False&thread.id=186974
Do any of the VIs do what you are asking for?
Since you are reading from a file, you may have to add thea read values in section to the code.
Cheers,
Flash P
Applications Engineering
05-28-2009 10:29 AM
I'm pretty experienced at processing all sorts of scientific data, but I'm having trouble understanding what exactly you need.
Can you post a picture of a graph of a portion of this data?
And then point out the wheat and the chaff?
Blog for (mostly LabVIEW) programmers: Tips And Tricks
05-28-2009 01:51 PM
05-28-2009 01:53 PM
05-28-2009 02:04 PM
05-28-2009 02:21 PM
05-28-2009 02:48 PM
The printed data doesnt print out the drop outs but rather show as blank spaces - but they are always there. Both signals are obtained from the same doppler so it is very prone to movement artifact - though not usually as plentiful as these files are. Here is the sample chart you requested. The data are sampled at 10 per second - a rather low frequency due to my former hand processing and needing to handle the lowest possible.
05-28-2009 03:17 PM
Ok first try. It is better now
05-28-2009 03:47 PM
