Removing a DC offset from Dynamic Data Type
I am using the DAQ Assistant to read 6 channels from a PXI-6281.  The signals of interest are approximately 90mVAC (60Hz) with up to 250mV DC Offset.  Can I programmatically subtract the offset from the acquired signals.  I tried the Express filter to no avail.
Frosty JG
(4,252 Views)
If you want to subtract, the subtract function works pretty well.
(4,244 Views)
Substracting an array from Dynamic Data Type bundle after DAQ Assistant doesn't work though. https://decibel.ni.com/content/docs/DOC-4441 provides a solution. Would you have a more simple and elegant solution?
(4,185 Views)
What could be simpler or more elegant than an add/subtract function. Why would you subtract an array? You simply use a constant.
(4,178 Views)
See pic of the vi (LabVIEW 8.5.1). After some time (from 2 to 20 hours of run time) a dt error comes up.
(4,172 Views)
What is the error? Why don't you have the subtract function inside the case statement. Then you would not need that silly local variable.
(4,168 Views)
Good call about the subtract.
Error -1802 Waveforms have different dt values
(4,163 Views)
