Remove plots from Mixed graph
Hello all
i need to delete a plots from mixed graph
best regards
Forza Juventus
(3,391 Views)
Use Delete From Array before sending the data to the graph.
(3,370 Views)
Thanks for your feedback ;
  In attached file you can understand my problem , when i increase the number of the plot  i have this error :
LabVIEW: Invalid property value.
Property Name: Active Plot
 Best regards
Forza Juventus
(3,358 Views)
Accepted by topic author moussadjenane
So your actual question is different then what you first asked?  (I edited the message subject to accurately reflect your issue.)
You can't set a property of a plot that doesn't exist yet.  All those plots don't exist until you write the data to the graph.  The graph doesn't get the data until after you've tried to set the plot names.
Solution:
Send the data to the graph before setting the properties for each plot.
PS:  If you searched the forums for error 1077, you would've discovered this message thread from someone else just a day prior.    Active Plot Error 1077
(3,328 Views)
Hello ;
Can you help me to how i can do it in the program ;
Best regards
Forza Juventus
(3,315 Views)
