Error200290
Hi all,
I got an error200290(DAQmx-write.VI)-The generation has stopped to prevent the regeneration of old samples. Your application was unable to write samples to the background buffer fast enough to prevent old samples from being regenerated.
Can anyone help me?
Mei
Message 1 of 8
(5,240 Views)
To avoid this error, you can do any of the following:
  1. Increase the size of the background buffer by configuring the buffer.
  2. Increase the number of samples you write each time you invoke a write operation.
  3. Write samples more often.
  4. reduce the sample rate.
  5. if your data transfer method is interrupts, try using DMA or USB Bulk.
  6. Reduce the number of applications your computer is executing concurrently.
In addition, if you do not need to write every sample that is generated, you can configure the regeneration, and then use the position and offset attributes to write the desired samples.
See: https://forums.ni.com/t5/LabVIEW/NI-DAQmx-200290-error/td-p/3367064
Message 2 of 8
(5,237 Views)
Hi Tom,
Thanks for your reply. I got these information, but I do not know how to realize them in the VI.... so, can you help me?
p.s 4.reduce the sample rate. This one cannot be used as the sample rate filled in is very low.
Mei
Message 3 of 8
(5,227 Views)
Message 4 of 8
(5,222 Views)
Accepted by topic author M.Mei
In addition to the good advice from Tom, I made a couple mods and comments in place in your code -- the pic will save me from typing 1000 words.
-Kevin P
Message 5 of 8
(5,203 Views)
Hi Kevin,
Thanks for your correction! Yes, it works well according to your suggestion. But in my application, xy scanning is conducted by two axis galvo mirrors, so, I need to  put 'duplicate' the vi. Error 50103 occurred while error 200290 came again when I used two channel. What should I do to solve this?
p.s Should I use Nchan version of DAQmx Write when I use two channels?
Mei
Message 6 of 8
(5,187 Views)
Hi Tom,
My hardware is galvo mirrors (Thorlabs, GVS012).
Mei
Message 7 of 8
(5,184 Views)
RE: error -50103
A good answer was already given here.
RE: error -200290
It'll be more productive (at least initially) to change the task configuration to "allow regeneration" while doing Continuous sampling OR change to Finite sampling.
    Either way, you probably need to first troubleshoot your algorithm that generates the 2 channels of data you want to generate via AO.  It'll be important that both channels have the same # points when they're part of the same task.  And the timing of how they vary relative to one another needs to be correct.  It isn't clear that you've got that part worked out yet.  It's pretty easy to make a subvi out of this signal generation and to put a waveform graph on the front panel.  That'll be a *huge* help in refining your algorithm.
-Kevin P
Message 8 of 8
(5,154 Views)
