Remove duplicate data from a txt file
Hi, I'm working with a VI which creates a txt file and it saves usernames (without password) but the problem is that this VI repeats the username, I mean if there are three people, Rose Jones, Sean Díaz and Rose Miles, the VI is going to write Rose, Sean, Rose. I need something that avoid or cancell writing same data until this person write something like RoseM.
Message 1 of 9
(4,351 Views)
You'll have to read your text file into memory and check for duplicates before adding more data.
Message 2 of 9
(4,340 Views)
As already stated, you will need to read the entire file.  I would recommend using a Set to store the values in.  If you then try to add a duplicate value, the set will not update.
Message 3 of 9
(4,331 Views)
The way you implement this depends on how you collect and store the data when you are looking for duplicates.
Can you provide the following info?
  • Is the data structure forced (i.e. First Name, Last Name or is his one string?).
  • Can this format change or is it fixed through a different interface?
  • Could someone put their first name last and last name first?
  • Do you need to check for that?
  • Do you want to force a format (i.e. The first letter of the first and last name are always capitalized)
  • Do you have an example file you are trying to update. This helps with understanding how you are storing your data.
  • What would you most ideal situation be for the end result?
Tim
GHSP
Message 4 of 9
(4,313 Views)
  • It's not forced, you can write Rose Miles, RoseM, Rose, Rose_Miles, etc...
  • This format it's only used in this part of the VI and also the name list is for show a list where you can select your profile and work in your session.
  • Just Select your profile from the list, and the list shows the duplicated names
  • Not really 🙂 I just need that the user don't repeat his nickname
  • Here is the VI I didn't create it, It was created by other person before me.
  • I Just need the user name and then create his personal folder. This last step it's completed
 Sorry, I'm beginner with LabView
Message 5 of 9
(4,286 Views)
Accepted by JoshX10
Instead of the Set File Position, use Read Text File.  Right-click on it and choose to "Read Lines".  Set the number of lines to read to -1.  This will read all of the lines and return an array of the lines.  You can then use Search 1D Array to see if the new user is a duplicate.  If it is, do not add it to the file and do whatever other rejections are required.  If it is not a duplicate, add it to the file.
Message 6 of 9
(4,274 Views)
I tried what you said but I think I did something wrong. I can't identify what it is, because I try to put the same name and the VI duplicated it again.
I send I picture.
Message 7 of 9
(4,239 Views)
Accepted by JoshX10
You are setting the file pointer to the end and then read everything from there.  But you are at the end, so you will read nothing.  So just remove the Set File Position.  Now after the read is done, the file pointer will be at the end of the file, so you can just write your additional value from there.  You really should close the file after the case structure.
Message 8 of 9
(4,203 Views)
Accepted by JoshX10
Thank you so much! Additionaly, I had connected User+enter insted of user, and that's why, at first your, solution didn't work, but now It works 🙂
Message 9 of 9
(4,152 Views)
