Remove VI From ALT TAB Menu
Hi all,
I have written an application which supports swappable UI's. This has been achieved by opening my UI through VI server and passing a cluster of the UI control references back to the main application VI and registering them for dynamic events.
The problem I have is that both my Main.vi and my GUI.vi's appear in the windows ALT+TAB Menu. I have set my Main.vi 100% transparent and removed it from the taskbar but simply cannot work out how (or if its even possible) to remove it from the ALT+TAB Menu.
Attached is a demonstration application showing my problem in LabVIEW 8.6. To see the problem, open Main.vi (ensure the block diagram is closed) and hit the run arrow. You will have one window displayed (GUI.vi) on screen and one in the taskbar yet two available via ALT+TAB.
Any insight into this would be greatly appreciated.
Kind Regards,
Steve
Message 1 of 9
(4,462 Views)
Accepted by topic author SteveBale
I have made slight modifications to your VI. I think this should work.
Message 2 of 9
(4,424 Views)
Brilliant! Thanks a million Smiley Very Happy
Message 3 of 9
(4,418 Views)
VooDoo,
Why does your image look like this?
Message Edited by Ravens Fan on 05-27-2009 11:49 AM
Message 4 of 9
(4,413 Views)
It appears the link to the image is to some /t5 subdirectory. I'm guessing it's another one of those "internal to NI only" links.
Message 5 of 9
(4,393 Views)
Hi VooDoo,
could you attach your pic to a forum message instead of directing to a 3rd party server? That way we all should be able to see your solution - which is interesting for me too...
Message Edited by GerdW on 05-27-2009 06:35 PM
Message 6 of 9
(4,392 Views)
It's not a third party server. With the upgrade to the forums and the new image gallery, the /t5 folder is where the images reside. Don't know why the X appears, though.
Message 7 of 9
(4,376 Views)
I'm not sure why this is happening. The image was appearing fine when I check it last!!
anyways..please find attached the image again...and the vi..just in case.
Message 8 of 9
(4,339 Views)
from here
Laura F. wrote:
altenbach: deleting an image will make it disappear from your posts; uploading files with the same name does not break anything; you cannot click on an image and have it open in a new window; I'm not sure if you can link to your image gallery outside of the forums, the intention is to use it for images you embed in your posts and avatars; the initial limit on gallery size is 1000 images and it can be increased if needed; the gallery does not have much organization
Oops..i think i know the problem now 😛
Message 9 of 9
(4,332 Views)
