Remote panel connection broken only when VI running
Using Web Publishing Tool, I have created a HTML page with an embedded VI and I saved it in LV Web Server's root directory.
I can take the control of the VI from my computer(using http://localhost ...).
If I want just to see the VI, it's OK if the VI is not running.
If I want to view the VI while it's running, after several seconds the connection with the server is broken.
(2,560 Views)
What is the processor loading while your VI is running? Is it possible that its loading down the processor too much? Is your application using a network connection for anything that could be conflicting with the server connection?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,560 Views)
