Remote high voltage enable/disable
Hi, I have got a DAQ SCB-68 board. I would like to establish a high voltage ON OFF options in LabView to be able remotely turn ON and turn OFF the high voltage for a cold cathode power supply (the manual is attached, see pp. 24 and 25), but I honestly do not know how to do it. Can anybody give me a tip please?
(3,242 Views)
The first thing you will have to do is get an actual DAQ board. The SCB-68 is just a dumb terminal block. Get a board that has digital outputs, wire one of the digital lines to pin 9 per page 24, drive the line high or low (True/False) with the DAQ Assistant or lower level DAQmx functions.
(3,228 Views)
Thank you very much, Dennis. Do you have a suggestion for me which DAQ board I shall buy (the cheapest one)?
(3,225 Views)
Accepted by topic author kirill_1980
NI has the 6008 and for students, myDAQ. Other vendors might be suitable. Depends on what else you might want to use it for.
(3,219 Views)
Thank you!!!
(3,199 Views)
