Remote debugging and file paths in executible
Looking for clarification about file paths when remote debugging a LabVIEW exe.
When I connect remotely and select a file control, I see the file system from where I am running the development environment.  This is not a problem since I can specify the target file by an absolute network path.
What I am not able to determine is the location of other programmaticly loaded files.  For example, I have some library function calls that specify .dll files by an absolute path.  How do I know which machine is the source of the .dll files when they are loaded after the debugger connects?
Ideally I would make sure the dll is loaded before launching the debugger but the VIs I am having trouble with are the ones using the dll so I need them to load with the debugger connected.
(2,358 Views)
The paths should be relative to (or absolute to, but that's not really a phrase - hopefully understandable at least) the target on which the exe is executed.
You can check this by moving/removing the dlls at the same path on your development computer - it should make no difference.
GCentral
(2,333 Views)
