Remote Configuration Project Explorer
From the Project Explorer, we need to configure a remote controller, changing the currently running VI, etc..
Making a VPN is the suggested method. In my case we are allowed to forward a limited number of ports for doing this, hence providing an IP as a remote conection.
At the Project Explorer Items, selecting a formerly available device CompactRIO Target, right-click on Properties, under General Category, you have the option for the IP Address / DNS Name.
Also, at the Project Explorer Items, at the Project .lvproj root element, right-click on New>Target and Devices, under Existing target or device, Specify a target or device by IP address, there is an IP address field.
I suppose VI Server and Web Server Categories are for other functionalities, not related to directly configuring the VI currently running.
In no case there is a reference of which ports are required to use.
So my question is which ports are actually required to be open for establishing a connection?.
(2,735 Views)
I think this article
Deploying a RT Startup Executable without the LabVIEW IDE
answers precisely the previous issue. What do you think?.
Thanks in advance.
(2,538 Views)
