NI 9411 for Serial Data
Dear all,
It is possible to use the NI 9411 for synchronous Serial Data reception?
For example, let have a stream at 10kbps data rate (33.3us/bit clock), from a serial sensor continuously feeding bits of data, separated by some given "delimiter".
Which would be the maximum data rate, if this module can handle 500ns?
Thanks in advance
Message 1 of 11
(5,404 Views)
Some additional notes:
  • Which is the maximum speed of this module?. In the datasheet the figure "Update Rate" reads 0.5us.
  • This means a clock of 2MHz can be configured for sampling digital inputs at this speed?
  • Can this module lock at a given external (or internal?) clock for synchronous communication as receiver?.
Thanks in advance.
Message 2 of 11
(5,369 Views)
Accepted by topic author NatineInsula
Hi hypfco,
Yes.
Yes.
No.
Why don't you use a serial port?
Message 3 of 11
(5,357 Views)
Is your data stream following a standard?  It would be easier if you got a module that just used that standard.  Otherwise, it seems like you should be able to do what you want if you are using a cRIO and program the FPGA.
Message 4 of 11
(5,340 Views)
@GerdW:
Thanks for your answer.
Because the NI 9411 module brings 32 DI at $251 through 1 slot, with a 4 slot NI cRIO, while the NI 9871 module brings 4 DI ports at $716 through between 4-6 ports considering at least 2 devices per trunk, with a 8 slot NI cRIO.
Message 5 of 11
(5,330 Views)
Hi hypfco,
your 9411 has just 6 DI ports.
The 9871 is a 4-port serial interface...
Message 6 of 11
(5,326 Views)
True. I am thinking in saving resources by using a NI 9411 32ch 1slot , instead of a NI 9871 4ports 4-6slots. If some programming is required to make that reduction, i would accept it gladly.
No, the data will be fed through a small PCB card I will design for this purpose. For converting a SPI/I2C sensor into serial data.
Message 7 of 11
(5,321 Views)
I made a mistake, i will restart the question.
Message 8 of 11
(5,320 Views)
There are libraries out there for performing I2C and SPI with LabVIEW FPGA.  You might want to look at those and skip your conversion board.  Another option is a USB-8451 or USB-8452, which are USB devices specifically made for I2C and SPI.  The LabVIEW API is really simple too.
Message 9 of 11
(5,302 Views)
@crossruiz,
Because i would use the data transmission between a large distance (more than 100m), i think the PCB interface will be required in any case.
Those I2C/SPI LabVIEW FPGA libraries will be really useful indeed.
Still, i am looking mainly for slot economy by choosing a module similar to the NI 9411 (and more similar to the NI 9403 as per my mistake). That's why i would prefer several channels modules + software configuration instead of few ports modules + ready to go configuration.
Message 10 of 11
(5,282 Views)
