Reload external files ?
I have a problem that's sort of a big pain in the a** :
I'm developing in VisualStudio .NET DLL's that then get used in LabView.
Whenever i re-compile the DLL in VisualStudio (cause i did some minor changes) i have to:
  1. close LabView entirely down
  2. re-open LabView
  3. reload the VI where the DLL is used
  4. delete the .NET Constructor-Node that references that DLL
  5. re-add the .NET Constructor-Node to reference the new DLL
  6. also delete & re-add all invoked methods & properties i connected.
  7. re-connect that .NET Node to the other elements
I have to do this because LV is caching like hell and there's literally no way to tell if it did load the new version until i do this burdensome procedure everytime. I've burned so much time already on this over the last week and this is slowing me down massivly.
Is there some sort of "RELOAD/REFRESH all external dependencies" button (sort of a Webbrowser "F5 key" just for LV) ?
(4,050 Views)
The answer is almost surely "No".  If you think that this is something that many LabVIEW Developers would like, submit it as a proposal on the Forum "Idea Exchange", which is designed to let LabVIEW Users tell NI what new features they need.
(4,032 Views)
Hi
The same issue and so far, no clean solution.
Imagine that for every single modification or debugging, you must do it again. 😞
Thanks for your consideration
(2,937 Views)
There is this,
But I doubt that it would cause a reload.
(2,922 Views)
@ESiTo wrote:
Hi
Better to use a .NET code to debug the DLL instead of using LV to debug the DLL.
Santhosh
Soliton Technologies
(2,917 Views)
I know it's too late for the original post 3+ years ago... but I have found that if you create a new DLL with the same version number then you have all of these problems, but if you have a new version number you only have a subset of these problems:
You do still need to do this (swapping the old DLL for the new one in between numbers 1 and 2):
  2. re-open LabView
But you do NOT need to do this UNLESS you are using .NET generics (such as Lists<>):
Even if you are using .NET generics then the only thing you need to do is number 6 and 7 on a few specific nodes that use said generic.
I'm not saying it's not a pain (it is) but it's not as severe by far if you just increment your version each time you build a new one.
(2,899 Views)
