Regular Expression for?
What would be the regular expression for extracting "LEDsOnFront" from the string "PUME-TestModules-LEDsOnFront-VIT.vit" (quotations not included)?
(3,025 Views)
Accepted by Rashid-Malik
Are you looking for whatever text is between PUME-TestModules- and -VIT.vit?  If so, try using Scan From String with a format specifier of "PUME-TestModules-%[^-]-VIT.vit".
(2,985 Views)
Well, I'm not sure what you're trying to do. The obvious answer would be to use the litteral LEDsOnFront as regex. If you want to remove this from
the string you can use the "search and replace pattern.vi" with this regex and an empty string as replacement.
If you want to extract any text between PUME-TestModules- and -VIT.vit you can use the following regex: PUME-TestModules-\K[^-]*
[^-]* assume that the string you want to extract do not contain an hyphen, If the string you want to extract can contain an hyphen use the following regex instead: PUME-TestModules-\K.*(?=-VIT)
Ben64
(2,970 Views)
