Registering DAQmx event to event structure not firing
I have created my DAQmx task for change detection on a digital IO channel (PXIe-1062Q; PXI-6527). In my VI i have registered the event in the same manner as the "DAQmx Create Event.vi". This event is needed only to capture a button press to start a test sequence. My the program compiles and runs but the event never fires.
(4,841 Views)
 Good morning,
Here is some documentation to help you in your use of the event structure in LabVIEW. https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html
You should not have to wire the event into the event structure.
Could I see what other events you have in your event structure?
Angie Cisneros
(4,765 Views)
Is your task running and acquiring data from digital line while you are waiting for this event?
(4,760 Views)
a.cisneros, attached is a snip of the other events in the structure. They are all mouse down events on front panel buttons.
(4,757 Views)
I have tried inserting a "DAQmx Start Task.vi" in between the task name and the reg events and that made no difference.
(4,755 Views)
Yes that was it. My big stoppage was inserting the "DAQmx Start Task.vi" before the Reg Events. Like a charm now!
(4,730 Views)
