Register with an Address and Data
Hello ,
I want to create a register in LabView with an associated address and data.I want to use this register with a load button to laod fpga  registers using serial communication.
Does someone can help me doing this with LabView,I don't have a lot of experience with LabView.
Thanks.
Message 1 of 16
(3,814 Views)
Hi Hamzo,
Sounds like you want to use a memory block in the FPGA, which uses "addresses" to read/write data…
This is where those "Training resources", offered in the header of the LabVIEW board,  come into play!
Message 2 of 16
(3,801 Views)
Hi GerW,
Thanks for your reply.
Exactly i want to reat/write data to and from the FPGA using serial interface.
I have to implement the registers using vhdl and then read and write to them.
Thanks for the resources.
Message 3 of 16
(3,767 Views)
Hi Ha_zo,
Which FPGA target are you talking about?
Which "serial interface" are you talking about?
Are you talking about NI hardware at all?
Why do you "have to" use VHDL when you want to use LabVIEW?
Message 4 of 16
(3,741 Views)
Hello GerdW,
I'm not using NI hardware ,i'm using an FPGA DE10-Nano from Altera.
The serial communication is RS-232.
I have two parts:
The registers that i have to create from the programmable logic part i have to use vhdl for that.
The Application part to read and write to these registers through the serial interface will be done using LabView.
Regards
Message 5 of 16
(3,728 Views)
Ok alright
Let's see what you have!  Seriously post some code!
You have registers
You have addresses
Maybe you have MODBUS?
"Should be" isn't "Is" -Jay
Message 6 of 16
(3,722 Views)
Well, it sounds like you are in full control of your protocol.  There are many options here, but I'll just send you to a presentation to give you ideas for how you want to format your messages.
VIWeek 2020/Proper way to communicate over serial
Message 7 of 16
(3,718 Views)
Oh, you have a  Chatty Cathy
Message 8 of 16
(3,711 Views)
I don't have Code yet.But will post soon
Message 9 of 16
(3,706 Views)
Crossrulz thanks for the links.
Will check-it out now.
Message 10 of 16
(3,705 Views)
