Refnum to Path odd behaviour
I want to get the file name from a refnum.
I understand that Refnum to Path does not work for configuration files.  According to help "You cannot wire configuration file refnums to refnum."  Why this is a special case does not make sense to me.
Regardless, I found a behavior I do not understand with this function.
Using Refnum to Path immediately after opening the file reports <Not A Path>, yet if placed in a sequence structure it does report the file name.
Back to my first task.  Is there anyway to get the file name from a config file refnum?
(1,761 Views)
Accepted by Mark_L
Here
(1,737 Views)
@paul
Thank you very much.  Exactly what I needed.
(1,731 Views)
