12-17-2018 12:10 AM
Hi
I am learning how to use reference handle,can someone explain how to use this, how to make the connecton,a example will be good.
Solved! Go to Solution.
12-17-2018 12:28 AM - edited 12-17-2018 12:28 AM
There are typically two "connections" (assuming these are part of a subVI). What are you actually trying to do?
Both should be no problem after a few basic LabVIEW tutorials. Start with those.
