Reference Becomes Null/0 When using in Cluster
Hello All,
I am Developing a driver for Configuration File,
I am Passing the Ref of the of the path after Opening the path in a Cluster to different states using **bleep** Register (using Single Run VI)
The Reference becomes null When calling second Time for a Different State
Same works fine if i am passing my Reference in a Shift Register without passing to Cluster
Whats the difference it will create when passing a reference in a Shift register using With Cluster and Without Cluster
(3,080 Views)
A **bleep** Register will never work.
But seriously, can you post a demonstration VI or at least a screen shot? The reference should not be closed automatically if you bundle it.
Oh, and I hope you know there is a build-in API for Configuration Files?
(3,050 Views)
typo (bleep)... Shift register
(3,046 Views)
