Refactoring LVOOP
All,
I am finding it very time consuming and error prone to refactor LVOOP code.  An example - I am writing a simulator for a plant that has about 20 remote IO nodes that communicate over modbus TCP.
I wrote a few classes to simulate these nodes, then decided to refactor them and promote generic modbus functionality to a base class, and change the underlying data structure from individual fields that represent each sensor/actuator, to arrays of booleans/U16's stored in a base class.
Now, instead of property accessor functions returning the value of each member of the private data, they go fetch the value from an array stored in the base class.
Refactoring the code to achieve this has pretty much broken the project completely.  I feel like I must be missing something here, but since refactoring is an integral part of object oriented development, surely there needs to be a capability to aggregate common properties and methods in to a common ancestor without having to rewrite/generate all of them?
Bruce
Message 1 of 11
(5,025 Views)
There really isn't an automated way to do that (at least not without add-ons).
After I got used to how LV handles classes, I do not have any problems with it. LV could use more features to move methods around for sure...
If you have a concrete capability\feature (more concrete then "refactoring is hard, make it easier"), you could post it on the idea exchange.
If this feels like a problem with OO, imagine the mess without OO...
Message 2 of 11
(5,013 Views)
I felt that:
"capability to aggregate common properties and methods in to a common ancestor without having to rewrite/generate all of them"
was a reasonably concrete feature?
I am fairly new to labview, and in my experience, there are very often easier ways of doing things that I wasn't initially aware of.  So, my question is more about whether such capabilities exist.
Bruce
Message 3 of 11
(5,002 Views)
@bdiesel wrote:
wiebe@CARYA wrote:
If you have a concrete capability\feature (more concrete then "refactoring is hard, make it easier"), you could post it on the idea exchange..
I felt that:
There are a lot of ifs and buts How exactly would this be triggered (where do you click)? The parent already has the VI. There is code in it, is it replaced? By a child method? Which child? What happens to the other child's methods? And so on. I think in your situation all of these questions have reasonable answers, but do they scale to all situations?
A solution that works in trivial situations might turn into an auto-destruction feature for more difficult situations (like the diagram clean upSmiley LOL).
There have been related posts about moving private data to parents, and how that is prone to errors if it's not removed from child private data. But I don't see how that process could be automated.
I'd like some functions to move a VI (method) to it's parent (instead of remove\rename\add\replace inputs and outputs). I think some add-ons facilitate that, but I don't use them.
Message 4 of 11
(4,997 Views)
The closest i can think of is cloning a class with the data you want in the parent and set it as parent. There are functions for that in G# (cloning classes and cloning methods between classes and change inhertitance) and it should work with native classes also to alleviate some pain, but yes, refactoring can create a whole bunch of issues to untangle until it works.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 11
(4,969 Views)
GDS (and more specifically its open source variant OpenGDS) add a bunch of useful OO automation tools to the IDE, as well as an optional framework. Not sure if the refactoring you are looking for is in this list but, as long as you don't use the optional framework, the IDE automation tools would still be useful for you regardless.
Message 6 of 11
(4,953 Views)
wrote:
@bdiesel wrote:
I felt that:
I'l investigate the add-ons.  Manual methods are error prone and time consuming.  Which means refactoring tends to be delayed until it becomes absolutely unavoidable.
Message 7 of 11
(4,932 Views)
Great, I'll take a look.
Message 8 of 11
(4,929 Views)
Both problems disappear when you done it for the 100th time Smiley Frustrated.
I agree thinks could be done to make it easier. Not sure why it's not happening. I like to stick to plain LabVIEW, no add-ons, simply because I can't depend on their presence on all machines I use.
If I needed something like this repeatedly, I'd make a script VI to do it. But promoting scripts that moves some stuff like I want it to, to build-in features is not likely to happen. Naming the menu item is just one of the problems ("Right-click>Advanced>Aggregate Common Properties And Methods In To A Common Ancestor" won't make it). Explaining what it should do is exactly is another. Finding consensus about what it should do exactly another.
Some basic tool additions would go a long way. For instance, we can create an overwrite method in a child. Why is there no option to create a base method in a parent (copied from a selected child)? That would help in your situation, but it's only one step.
Moving private data from several childs to the parent will be very tricky. I don't think I'd like LabVIEW to do that. What happens to unbundles in the child methods? Replace them with VI's? What if in placement structures are used? The VI's have error handling. Should it be used? The clusters didn't... It will create a mess.
Message 9 of 11
(4,918 Views)
Well, this is why there is a recommendation to only ever access private data via inlined accessor VIs (No Errors).
It feels like overkill when dealing with classes, but it makes refactoring a whole lot easier.
Message 10 of 11
(4,909 Views)
