Redhat driver for Compact RIO
I'm moving a project from Windows 7 to Redhat 7.  When I went to open the project in Redhat I get the following error:
Error: Missing NI Module, Toolkit, or Driver
NI CompactRIO Driver support for LabVIEW 2017 is missing and is referenced
NI R Series Multifunction RIO Driver support for LabVIEW 2017 is missing and is referenced
I started by trying to resolve the NI CompactRIO Driver issue, but when I tried to find the correct driver for Redhat, all I could find was the NI-RIO-17.0.0-Linux.iso.  After installing it successfully, I still get the same warning, which made me think that it wasn't the correct driver.  I saw that there is actually a driver named NI-CompactRIO for Windows.  Does this driver exist for Redhat?
Also, I haven't had much luck finding a Linux NI R Series Multifunction RIO driver. The one I have found that says Linux, links to a .exe
(2,983 Views)
From a question I asked earlier, I explored someone's solution, and found this document, which says:
It is not currently possible to program FPGA bitfiles for NI FPGA-based devices from the LabVIEW development on Linux.
I guess that answers my question.  I have to do all development on Windows, and then run on Linux.
(2,966 Views)
That document is not for compactRIO.  But you are correct, development happens in Windows.
I would check that the communications from the cRIO are supported in Linux; e.g. TCP should be supported but maybe Network Shared Variables are not (check first).
FYI, the newer cRIOs are running real-time linux https://www.ni.com/en/shop/linux/introduction-to-ni-linux-real-time.html
ALE Consultants
(2,951 Views)
