Red outline around my code.
I was writing some code and by accident I did something and now I have a red outline around my screen and when I stop with the stop button the screen flashes and it goes into pause mode. How did I turn this on and how can I turn it off? Thanks in advance I am using Labview 2011
(2,909 Views)
Thats a break point that you've managed to put around the whole VI.  Use the break point tool to undo it.
(2,906 Views)
on the block diagram.  Shift+right-click to show the tools palatte- select the breakpoint tool
OR Menu View>>Breakpoint Manager and delete the breakpoint
"Should be" isn't "Is" -Jay
(2,905 Views)
Thanks that took care of it!
(2,899 Views)
Dont forget to Kudos and mark the answer that gave the solution.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,871 Views)
