Recover corrupted LLB file
When I tried to copy a vi into a LLB through network, my *.llb is corrupted. Thrying to open it, Labview says
that it cannot list the llb-content.
Is there any way to repair my llb or to extract the vi-files out of it.
Thanks for any help
I searched solution, it said can get back from temp directory, may I know where is the temp directory?
(6,586 Views)
The LLB file is
(6,577 Views)
Suggestion 1: Don't use LLBs. You just found out why. LLBs are a left-over from when Windows could only handle 8.3 names.
Your temp directory is specified through your LabVIEW options. From within LabVIEW select Tools->Options, and look at the "Paths" tab. The temp directory is usually "C:\Documents and Settings\youruserid\Local Settings\Temp". Note that if you rebooted the machine it's likely you won't find the temp file.
Suggestion 2: Send the file to NI. They can sometimes recover corrupted LLBs.
(6,560 Views)
turbot,
I ran the "llb decorruptor" on your llb and unfortunately it wasn't able to recover any files from your llb.  This sometimes happens when the corruption in the llb is in a particularly bad spot in the file.  I would reccommend using a backup of this llb file if you have one somewhere.
Justin D
(6,545 Views)
(emphasis mine)  I just corrupted an LLB as "user x" then rebooted, looked up this page, went to my temp directory and found an uncorrupted version of my LLB.  It was uncorrupted because I had recently used it as "user y".
I then copied the uncorrupted file to every disk drive within reach and vowed never to go so long between backups again.
Thanks for the tip!
(6,314 Views)
