I am trying to reconstruct the recorded Baseband IQ Signal in the QAM mode or in the Interpolation mode at 70MHz using NI-5640R.
Details of the recorded file is as follows
Samplerate : 3.125MSPS(3.125MSPS of I and 3.125MSPS of Q)
bits per sample : 16bits for each I and Q
Allignment of data: Alternative I and Q
I have tried in the QAM mode. The code is attached. I am able to generate the signal with some gaps. But I need to generate the signal continously. I need to get the data from file and I need to generate the signal continously with out interuption till the end of file.I am using LabVIEW 8.2 and the version 1.2 drivers.
