Formula Node & Array Operations
I'm trying to use the formula node to subtract the previous term from the current term (or the next term minus the current term), but I can't figure out how to
use the array index to do it.
I've something along the lines of z_array[i+1]-z_array[i], but it only returns the difference of i+1-i....
Please see the attached picture.
Thank you,
(3,198 Views)
Accepted by topic author simply_me
Problem solved.... 🙂
(3,142 Views)
That would be so easy to do in pure Lv code.
Qestit Systems
Certified-LabVIEW-Developer
(3,131 Views)
