Reccomended Temperature-Humidity Sensor
I am looking for Humidity-Temperature Sensor which will be used with LabVIEW through  NI-PXI 6220.
I do not need the high solution sensor (+/-0.5C), but an easy to use as I am new with LabVIEW. To control the temperature and humidity of a chamber by measuring current data and turn ON/OFF the heater/humidifier when needed.
Is there any example for me?
Your reccomendation is highly appreciated.
Message 1 of 17
(14,222 Views)
For temperature i like to use this company...http://www.thermistor.com/productsDirecTemp.html I have found that there products work very well and they come with LabVIEW drivers.
Joe.
"NOTHING IS EVER EASY"
Message 2 of 17
(14,217 Views)
Thank you Joe,
Do you have any reccomendation for humidity sensor and coding example?
Message 3 of 17
(14,202 Views)
Omega has some humidity sensors which also report temperatures.  I have used their humidity-only sensors which produce a 0-5 V output for 0-100% relative humidity.  They have a variety of other types as well.
Lynn
Message 4 of 17
(14,196 Views)
Another company you could try is measurement computing. We use there stuff alot also.
Joe.
Message 5 of 17
(14,188 Views)
I have used Edgtech Dew Point Hygrometers for my work at NIOSH (National Institute of Occupational Safety and Health).
They will spit out the current temp and humidity via a serial port that can be easily sucked into a LV app.
Ben
Message 6 of 17
(14,186 Views)
I've used Precon Temperature Humidity Sensors.  They have an analog and a serial model.
www.preconusa.com
Message 7 of 17
(14,176 Views)
We have a few of these. You can talk to it through ethiernet. I had to reverse engineer the LabVIEW code
http://www.newportus.com/ppt/ITHX.html
They calibrate nicely and they have thier own web server.
See the attaced code that talks to the sensor to get the temp humidity and dewpoint. I was going to do more but who has time to do everything. (my boss thinks I do)
Tim
GHSP
Message 8 of 17
(14,171 Views)
here is a Ben quote just for you Tim.
The problem with being able to do everything is, you are expected to!
Smiley Mad
Ben
Message 9 of 17
(14,167 Views)
Ben, Tim, Arvin, Joe and Lynn,
Thanks a lot
Van.
Message 10 of 17
(14,148 Views)
