Real Time USB 3 Vision
Bonjour à tous,
Voilà ma question : je voudrais savoir si USB 3 Vision est supporté par un LabView RT (Pharlap) ou même LabView RT (Linux) sous une cible NI-GenericDesktopPC.
Car je souhaite faire du traitement d'image en temps réel avec une caméra en USB3.0 de préférence celle-ci :
Flea3 FL3-U3-13S2C ( http://sine.ni.com/apps/utf8/nipc.specs?action=view_specs&asid=1102&pid=11401&tier=3 ).
Et aussi, de savoir s'il faut une carte spéciale NI pour du PCI vers de USB3 sous LabView RT.
Merci d'avance.
(3,024 Views)
Hello Jamesvirus,
Thanks for posting over here!
If you want to post a question in French, then it might be best to post questions in the French section of the forum:
http://forums.ni.com/t5/Le-forum-francophone/ct-p/FrenchForums
If English is ok for you, then it might be best to post this question in a Vision or Real-Time/Embedded related part of the forum:
http://forums.ni.com/t5/Machine-Vision/bd-p/200
http://forums.ni.com/t5/LabVIEW-Embedded/bd-p/420
Just to make sure I understand the question corrently.
You are currently using a normal desktop with a USB3-controller, right?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,957 Views)
I'm sorry.
I don't use a normal desktop equip with a USB 3-controller at this time.
But i want to use a camera USB 3 Vision with a normal desktop running on LabView RT OS ParhLap, not a Windows.
I don't know if this is possible or not.
thanks.
(2,944 Views)
I think I might have been unclear to you.
I had understood that you wanted to use LabVIEW RT on a normal desktop PC.
With the "USB3 controller part" I actually mean "does the Desktop PC itself have USB 3.0 ports or USB 2.0 ports".
Kind Regards,
(2,937 Views)
The Pc have a USB 2.0, but i think bought an adapter PCIe to USB3.0 for this computer.
NI-IMAQ don't support the USB 2.0 camera, but USB 3.0, i don't know.
(2,934 Views)
