Real-Time FIFO instead of "Chart History Length"
I was wondering how I can implement the following method with Real-Time FIFO instead of "Chart History Length"
Message 1 of 11
(3,778 Views)
Here's NI whitepaper about RT FIFO. I would suggest u to read more specifically in first and third section (Using RT FIFO):  http://www.ni.com/white-paper/3934/en/
Message 2 of 11
(3,763 Views)
Is there any way to read all the data inside a RT FIFO regardless of the size of the FIFO or the amount of data available in the FIFO?
I mean in every iteration of a loop, I want to read all the data in the RT FIFO and make the RT FIFO empty.
Message 3 of 11
(3,756 Views)
Accepted by topic author Cashany
Yup. It uses two FIFO read nodes. The first one reads 0 elements, and the output for Element Remaining is wired to the second node's Number of Elements input. Voila, you check what's in the FIFO and pull everything out of it.
CLA
Message 4 of 11
(3,753 Views)
Got it.
Message 5 of 11
(3,751 Views)
So how does one read 0 elements from the FIFO?  Are we discussing the RT FIFO Read (primitive) or the Shared Variable with RT enabled?
Message 6 of 11
(3,712 Views)
Actually, In every iteration of the loop, I will write 100 elements to the RT FIFO and then will read all the remaining elements from the RT FIFO.
When I write to the RT FIFO I can get the number of elements remaining in the RT FIFO, then I can wire the number of elements to my read function.
So, in my case I don't need to read 0 elements from the RT FIFO.
Sorry, I couldn't help!
Message 7 of 11
(3,707 Views)
FIFO node in RT host :]    Just little trick to pull everything from the queue.
Message 8 of 11
(3,699 Views)
This is a Property Node, right? ... thanks, I'll read up on them!
Message 9 of 11
(3,680 Views)
Ok this is not a Property Node, but a Method Node, correct?
Ref: http://zone.ni.com/reference/en-XX/help/371599G-01/lvfpga/fpga_fifo_method/
Since this is for taking action on a FPGA VI, would the node be available if one is running the cRIO in Scan Mode?
Message 10 of 11
(3,628 Views)
