Reading voltage on a thermocuple channel
Hi to everyone
I have a thermofluxmeter sensor that is a thermopile.
To use it i have to read the voltage it provides and convert it to my measure. Long story short the voltage value are in the identical range of a thermocouple so i would like to use a thermocouple channel but instead of having the converted and compensated value, i just want to obtain the raw voltage out of a channel of a ni 9212 moudle for compact daq.
Does anybody knows how this can be done?
Thanks a lot
(2,626 Views)
Accepted by topic author ar25
You can create a DAQmx Voltage task, and setup the channel as one of your thermocouple inputs.
Rhys
(2,614 Views)
Thanks a lot.
I did it and it works. but just to be sure if i do this way it'll not do any compensation?
(2,582 Views)
