Ni-6259 is in yellow colour symbol ( NI -max )
Hello all,
 I have found that under an NI max  --> devices and interface --> NI 6259 is showing in yellow colour ( simulation mode ) symbol instead of Green colour  . but it passes a self test and reset successfully . i dont know what was the reason ?  under remote systems also it was configured under an ip address . pls help me with your ideas .
(2,194 Views)
Hi bhuvanesh,
The reason for the color is easy: YOU created this device as simulated device…
And yes, even simulated devices will pass the selftest (more easily then real devices)!
A NI6259 was configured as "remote system" with an IP address???
Why don't you show a MAX screenshot when you ask for MAX problems?
(2,191 Views)
