Reading the xml file and sort
Hi all,
I need to read the XML file and sort the content in that. but initially, I had a problem with the reading itself.
the error stating that file was empty. but the file has a content .
I read ( opened ) the content and verified using the MS access database.
 expecting your ideas
Message 1 of 12
(4,505 Views)
audit date.vi ‏is empty
Message 2 of 12
(4,489 Views)
Hi artem ,
pls find the attachment .
from the XML file, i need to extract the first column ( date ) and sort.
Message 3 of 12
(4,479 Views)
You can't read no-LV xml by LV-reader.
Do it manual
Message 4 of 12
(4,473 Views)
Do it manual
 although "parse XML fragments.vi" does take some amount of time to execute,
  using "parse XML fragments" on "audit.xml" from the zip-file results in the following:
Message 5 of 12
(4,467 Views)
Hi artem ,
i am new to this domain .and expecting the guidelines
pls attach the vi file
More over ParseXML fragments.vi is available under which palette ? i dint have it
i opened by MS access database. for sample just see the format of the file . ( find attachment)
i need to sort the date ( first column )  . For that ? is it possible ?
Message 6 of 12
(4,449 Views)
Place Read From XML file.vi on BD and open it. You'll find how it works.
ParseXML fragments.vi is part of BD, I've taken it from here, not from menu.
My image is snippet, so you can save it and drag on your BD.
Message 7 of 12
(4,386 Views)
Thanks artem ,
but the vi taking so much time to list out the output . what was the reason and how to avoid this ?
Message 8 of 12
(4,336 Views)
I think you can't avoid long waiting.
You source file too big for fast working.
If you need work with file many times, better resave it in binary format or into DB
Message 9 of 12
(4,332 Views)
If you really need to reduce your execution time [You need to develop your own LV code by invoking MSXML] which will reduce your execution time.
Message 10 of 12
(4,329 Views)
