Reading of the Labview SubVIs when opening a VI increases in reading time in enermous steps
The reading of SubVIs when opening a VI takes longer everyday.Doubled to one hour over night!!!!!!
Is there any temp folder that can be removed, any test VI for checking reading algortihms or anything else to check this?
We are using Labview 2009
It doesn't matter which account we use, thus it must be on the overall installation.
Thanks for any hints.
(2,763 Views)
@Kilian Baur wrote:
The reading of SubVIs when opening a VI [...]
I don't really understand what "reading of SubVIs" means.....I assume that you are talking about loading times.
If you did not do it before, maybe a reboot (no hibernate or sleep!!!) can help. Another thing is a masscompile on the VI hierarchy of that VI.
If nothing helps, you have to give some figures on:
- CPU load
- Memory usage
- Steps to reproduce
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,754 Views)
Do you have a network path involved here, either defined in your search paths or you are obtaining the VI from a network path?
Ray Farmer
(2,749 Views)
We checked your hints (Norbert) but it didn't help so far. But thanks anyway.
We will check the network issue. Thanks.
(2,742 Views)
