05-05-2008 03:58 AM
05-05-2008 04:01 AM
Hi anivij,
how do you transfer the data from *.xls file to *.dat file? Do you use ActiveX?
Mike
05-06-2008 12:31 AM
05-06-2008 12:57 AM
Hi anivij,
i think you should also use the ActiveX function to read your data. Is it possible for you, or do you have special requirements for it?
Mike
05-06-2008 01:07 AM
05-06-2008 01:25 AM
Hi anivij,
attached is an example for you. The interesting cases for you, are the light blue ones.
Hope it helps.
Mike
05-06-2008 01:27 AM
