Reading multiples data files individually
Hi there,
I made a program that writes Spectrometer Data into multiple .lvm files.
They are saved in the same folder with sequential names like "file_001.lvm", "file_002.lvm", "file_003.lvm", "file_004.lvm"...
I am using the "List Folder.vi" to list them all and want to read them individually and to choose them while the program is still running. I expected that I could use a control (like a slide) on the Front Panel to do so, setting it to 1 to read "file_001.lvm" and setting it to 10 to read "file_010.lvm", and so on.
Is there a way to do so? I need a light on how to do it.
This control should modify the filename to be read by the "Read Measurement File Express", but I don't know how to do it yet.
I was thinking the name has a "base" that is "file_" and I only needed to modify the rest of it so I can choose between files. Am I right?
Thanks in advance,
Liepo
PS: I'm sending my program as it is and a folder with the files. It reads the files sequentially and then stops. I want to be able to control which file it reads instead of this automatic iteration.
(4,075 Views)
Accepted by Liepo
You probably want to do something like this:
(4,067 Views)
I would populate a List Control with the file names and let the user select which item to look at from that.  Play around with properties from the list control.
(4,065 Views)
Thank you very much,
I think this will do, could you post the VI?
I'm using labview 2012,
Liepo
(4,027 Views)
I think it's fairly simple and it would help you to try to reproduce it yourself. I'll still be around if you have some trouble.
(4,001 Views)
 Thanks Manu,
I managed to do it, and it really was pretty simple. It was good to learn in the process. (:
(3,918 Views)
You're welcome. I'm glad it helped!
(3,910 Views)
