Reading lines form a text file formatted in a specific way
Is there anyway of, when reading a text file, to only process data formatted in a certain way. I have files of data with a header that I need to ignore so this would be very useful.
Thanks in advance
Jack
Message 1 of 12
(3,571 Views)
could you post one of these files? and specify please which exactly fields you need to read
Message 2 of 12
(3,564 Views)
and yes, do you want to read them into array or only once?
Message 3 of 12
(3,560 Views)
Ah, I suppose that would be useful. Please see the example attached
Message 4 of 12
(3,529 Views)
got it
Message 5 of 12
(3,527 Views)
...and I am reading them as an array.
Message 6 of 12
(3,526 Views)
Try this out I make a subvi for you.
Message 7 of 12
(3,514 Views)
Thankyou very much.
Unfortunately I am running Labview 9 and there is an error message when I try and open/run it - is there any chance you could take a screenshot of the block diagram?
Thanks again
Message 8 of 12
(3,509 Views)
@jnaumann wrote:
Thankyou very much.
Thanks again
Message 9 of 12
(3,501 Views)
Actually I decided to inmprove it a little bit, to read the data a little faster, you will see why.
Message 10 of 12
(3,499 Views)
