Reading images efficiently
Something like this should do :
Epictetus
Antoine Chalons
Message 11 of 25
(2,109 Views)
I'll try this
Message 12 of 25
(2,108 Views)
What is the name of the function placed under 'index array' function? I cannot find it.
Message 13 of 25
(2,101 Views)
Accepted by bikekowal
"delete from array", indeed it's icon changes slightly depending on what in conneted in.
but the png I posted is a snippet, it means it contains the code, download the png to your desktop and then drag and drop the file on an empty block diagram, it will import the code, magic!
Epictetus
Antoine Chalons
Message 14 of 25
(2,098 Views)
This 'snippet' is amazing. I haven't seen that before, it is really great tool.
I run the code and unfortunately got a following error:
Error 16 occurred at Read BMP Header Info.vi
LabVIEW:  Image not found.
NI-488:  SRQ stuck in ON position.
Message 15 of 25
(2,096 Views)
I restart the computer and now its working. And as I see, the application is working quite fast. Thank you very much for your help 🙂
Message 16 of 25
(2,089 Views)
Maybe you help me with another thing - is it possible to delete a file after reading it? I mean delete an image from disk after displaying it?
Message 17 of 25
(2,084 Views)
sure, in the "file" >> "advanced" palette, there is a "delete" primitive.
Epictetus
Antoine Chalons
Message 18 of 25
(2,080 Views)
OK, thanks, but I rather mean deleting the file automatically - I get one image, display, delete then get another one, display, delete and so on... Till tomorrow I won't have a chance to check it so will this be ok?
Message 19 of 25
(2,074 Views)
Epictetus
Antoine Chalons
Message 20 of 25
(2,069 Views)
