Reading dual channel
Hi guys,
I need some help on record dual channel data.
I can show and record a single channel each time, but I need to show them at the same time.
Thanks!
Rookie
Message 1 of 8
(3,140 Views)
STOP posting the same question over and over again. This is the third thread you've started.
Message 2 of 8
(3,131 Views)
Accepted by topic author RawtoLV
EDIT: did not realize he had asked this numerous times.. (OP) ,I suggest you follow the answers/help/hints given previously  Smiley Wink
Message 3 of 8
(3,120 Views)
mission completed!
Sorry about being annoying. Smiley Embarassed
Message 4 of 8
(3,112 Views)
That example has no timing information so when you save to file, that will be missing and it is generally important to include it.
Message 5 of 8
(3,099 Views)
noted.....
Message 6 of 8
(3,094 Views)
Copy that!
I will connect the interation terminal with the data!
Thanks for reminding!
Smiley Tongue
Message 7 of 8
(3,082 Views)
I don't understand that. You would simply change the DAQmx Read to return a 1D waveform data type.
Message 8 of 8
(3,073 Views)
