Display images from a database
LabVIEW 2013
SQL Server 2012
I would like to read an image path from a SQL database and display the image on the front panel in LabVIEW. I have attached an image of what I have so far.
I have not lost my mind, it's backed up on a disk somewhere
(3,306 Views)
What do you need help with? First off, you are flattening the variant to a string which is going to return a binary string, not a human readable string like you appear to be wanting. Use the Variant to Data function to cast the variant to a string. Is the database portion of the program working as you expect?
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(3,281 Views)
When I run that VI I get error 7 saying unexpected character are in the file path. The file path is a C directory path to a folder of images that are linked in the database. The links are in varchar format. I'm out of office until tomorrow but I will try your suggestion then. Thanks for your reply
(3,275 Views)
