Reading data using Modbus RTU
Hi bestecf,
why do you connect a device using a RS485 port to a device dedicated to RS232 ports?
Does your hub support RS485?
Message 11 of 17
(1,712 Views)
@GerdW wrote:
Hi bestecf,
I created this drawing by looking at the device. Yes, I noticed the part you were talking about. Because the hub does not support RS-485. I thought the ORDEL PC771's rs-485 output was converted to rs-432 on the port. Afterwards, connection to HUB was provided. I think this is the case if possible.
In Labview, should are being MB Serial Example Master.vi and MB Serial Example Slave.vi run at the same time?
(But, 1 COM Port is used )
Message 12 of 17
(1,698 Views)
Again hello, I continue.
Purpose: Read value from temperature display device with MODBUS RTU Serial communication.
I attached .vi that I tried. Baud rate: 9600, Parity: even, slave addr: 1
1) What should I change or add to read data and show data out ?
2) When I put serial usb cable, there are multiple options in VISA. (COM1-COM11-COM10-COM2)
How do I know which com port the data flows to?
Message 13 of 17
(1,666 Views)
I guess LabView 2019 version is not open. Can you see my problem onto this screenshots? Thanks.
Message 14 of 17
(1,648 Views)
Hi bestecf,
LabVIEW2019 is "open" - but as it is rather new (just 3 month) not so many people have it installed yet (including me).
No, as there is no error visible in your images.
Do you get any error when running that VI?
Message 15 of 17
(1,642 Views)
@GerdW wrote:
Hi bestecf,
In this vi, there is no error yes. But, there is a purpose that needs to read value from temperature display device with MODBUS RTU Serial communication.
2) When I put serial usb cable, there are multiple options in VISA. (COM1-COM11-COM10-COM2). How do I know which com port the data flows to?
Message 16 of 17
(1,640 Views)
Hi bestecf,
1. Read the manual of your device. It should contain the information you need…
2. Read the manual of your USB-Serial converter. It should contain the information you need.
2a. Test each COM port for responses of your device when you send a command…
2b. Why are there 4 COM ports? Does your USB-Serial converter provide 4 physical ports?
Message 17 of 17
(1,633 Views)
