Reading data from LVM
Hi!
I am using Labview 8 and my problem is the following: I am acquiring
data with the DAQ Express VI. The data is then written into a .lvm file,
which seems to contain the data (I have succesfully analysed it with
other software). But afterwards, I can not read out the lvm file with
the read from measurement file express VI so that it is displayed
correctly: I have tried the example Read Signal.vi, and I have tried to
connect the read from meas file.vi directly to a waveform chart or a
waveform graph (without while loop), but the data is not plotted correctly.
Could you point out were I am making a mistake?
Thanks for the help!
Karim
(3,551 Views)
Hi Karim,
It's quite hard to figure out what the problem could be, but as attachement you will find a little example, maybe it helps you to find the problem!
Regards, Chrisitan
(3,537 Views)
Christian_M wrote:
> Hi Karim,
> Regards, Chrisitan
Thanks for the answer, but I have tried your read signal from file VI
with my lvm files, and it still does not turn out right. I have now a
workaround that uses the spreadsheet i/o VIs, but I am still intrigued
why my lvm files are not read correctly...
Karim
(3,532 Views)
You should attach an example of one of your lvm files and the VI that you used to create it.
(3,524 Views)
