Reading a BMP File by Pixel and plotting into a waveform graph
Hi Enriquez,
you have an array of pixels. All you have to do is using the correct indices to read the pixels values! Come on, just some simple math involved...
Is it so hard to calculate the needed x/y indices?
Where do you find the center of the image? Something like x-size/2 should do the trick...
Message 11 of 17
(1,272 Views)
@Enriquez wrote:
What I meant is how do I manipulate the array to read from the center to the right diagonal? and how do I make another graph that shows the upside down result of the radius graph?
Hi enriquez!
Maybe you are supposed to look "straight forward" on the output array of the "unflatten pixmap.vi" which is called "24-bit-pixmap" in the attached .vi
Is this what you are looking for, or did I get you wrong?
Message 12 of 17
(1,248 Views)
oh and how do I delete all duplicated entries in the 2D array output after the Split number function? So that I have 1 entry instead of having 3 of the same duplicates
Message 13 of 17
(1,247 Views)
Hi LHX,
are you working with enriquez now or do you still do your own edevelopment on the same topic? 😄
Use a loop with some comparison functions to keep only unique values!
Message 14 of 17
(1,240 Views)
Hi alexderjuengere!
Thanks for the help but unfortunately I couldnt open your vi as Im using the older version~
Message 15 of 17
(1,210 Views)
Yes we're working together!
we're using version 9, could someone help us to convert over to version 9?
Thanks!
Message 16 of 17
(1,204 Views)
Hi alexderjuengere,
Thanks for the help once again!, the one that you gave me is what I'm looking for.:)
Message 17 of 17
(1,171 Views)
